JKbrick
Yup, and only for an hour per sermon - what a life! :cheesy:
Yup. Yup. Thank you for what you do
Are you guys getting shorter shocks then too?
Got my Rock Stars today (thanks Northridge) and will install this weekend, these instructions sure help. :clap2:
Your CO kit didn't come with Rock stars?
Sorry, I removed my question after I clicked the link up top and realized that they are indeed bolt on. Will add these to the spring mods list.
Nope, an accessory I'm told. Looking at the install it doesn't seem too hard.
BTW - I don't have coilovers
What advice are you looking for? I use synergy's upper and lower shock relocation brackets. The lowers move the bottom of the shock up about 1.5 inches(and I have the ones that include the skid). The uppers move the upper mount up an equal distance so no need to change shocks. The upper does change the angle a little, nothing I notice though as far as ride quality. No binding that I can tell.jesse0920 said:I know there are other companies that make rear upper shock relocation brackets to be installed with lower shock relocation brackets such as the EVO Rockstar skids. This is to mitigate the need for new shorter shocks or larger bump stops. They do seem to change the angle of the shock so I'm sure they probably change the ride characteristics a bit. Can anyone who has installed the upper relocation brackets offer up some advice.
Good luck Aussie!
Thinking about this now aftyer being done - get a Sawzall - seems like it would be way better than cut-off wheels on a 4" grinder. :twocents:
