Would this also affect the Bluetooth u connect volume? That might be a positive to all this. But higher, distorted sound doesn't necessarily mean better.
How's the sound quality with the jumper?
Because I'm a fucking nerd and tech guy, I just bought a db meter so I can put this thread to the test. Stay tuned, pun intended, for some verified results soon.
I don't think you're going to see anything different with a db meter. It would take twice the power output +\- to notice even a 2db +\- in volume output. But, if your'e going to do it, do it in a garage with the garage door closed and with test tones, not music.
Well I just tried a little experiment whereby I left the stereo on, and unplugged the connector. An interesting thing happened, about a half second after unplugging it, the sound went dead for a second or two. When it came back, I couldn't tell for sure if there was a change in volume, but maybe. The same thing happened when I plugged it back in. Anyway, the sound cutting out is odd, since I've never experienced that when I unplug my door connectors, and i frequently have the stereo on, then. This phenomenon might lend some cred to there being some programing to adjust the volume when that plug is out/in.
So some interesting results to report... With the jumper in:
https://youtu.be/_QUBaoOQmY4
Without:
https://youtu.be/mW82RIZt2ao
My test harness:
My sound meter:
So basically I'm finding the exact opposite. With the jumper is in the volume is lower. When you remove the jumper (or top) it's higher.
Not sure where you got this from, but in my test it's wrong.Yep, but yes you are right, the radio isn't as loud when you unplug the connector.
So the weather ended up being pretty shitty for our meetup and so hanging outside wasn't really an option. (We ended up getting a foot of snow that day)
Therefore I wasn't able to test this out in any one else's JK, but we can definitely do it another time. It also should be noted that I was working on my hardtop hoist yesterday in the garage and just unplugging the top there was a noticeable difference in the volume. I sat there and plugged/unplugged while listening to the radio and you could hear the volume got louder when unplugged. I'm not sure why the theory was that it was lower, but it definitely is not.....at least on my JK.
I've got a soft top on mine if you want to test. I've got a 2014 with the subwoofer
I think we really need to test on the 07-11 generation.
The 08 I had was the same to me as my 14. When you unplugged the connector, the radio shut off and came back on but I couldn't tell a difference in sound. Neither could anybody else that looked at it.
