Mrs.2013rubirick build thread
She's all done!! Well still a few things like rock rails, c gussets, and a few other things.
Thank you again everyone! It was a really fun weekend! Can't believe we got so much done 😆
Just one thing, I was bottoming out a bit in the rear. Everything else was great. We're going to wait for the rear sway bar and then see.
The swaybar won't make a difference on that. That's crazy with the 300 springs in the rear. I put the tuning rings all the way down.
If this is the same crew that did Branmans, check that the front axle is centered and cycle the suspension on driver AND passenger.
He posted up some issues after his first run. Maybe save you some headache. 👍
You mean like this? It must have been the people doing the work? Make a comment when you actually wrench on your jeep. :idontknow:
Have you ever installed a set of coil overs(or anything for that matter) if not pls don't comment
Edit. We're a gang not a crew remember
Hahahahahahaha! So true!
Love the Web Wrenches out there!
Sensitive much. I don't need to have installed COs to read the thread and see a problem.
Just thought I'd give you guys a heads up if you hadn't seen what branman posted. Not sure what the issue is but honestly figured you'd be able double check. That's all. 👍
Apparently I rattled the hornets nest though. Good times. You should clearly know my intensions if you've spent any time on the open forum.
