2nd.gunman
i should have said make sure the sway bar angle is in spec... i replaced my original coils with 4" Plush and they were taller than i expected. the extra height was enough to put the sway bar angle out of spec (too low, softer...higher firmer (insert bad jokes here)), once i got it back into spec the body roll got back under control and then i adjusted the shocks to fine tune it all. it.
Link length doesn't affect swaybar spring rate at all.
