WAYALIFE on the GO : Miscellaneous Photos from Cindy & Eddie!
Some stupid questions: the bend in the track bar, does it need to be there so when you up travel, it's there as a cut out for the driveline?
How do you adjust ride height?
What you're looking at is a factory rear track bar. Truth be told, it doesn't matter which way the track bar goes and it sits completely over the diff housing so it would not get in the way of the drive shaft. At the moment, there is no way for me to adjust ride height as I don't have the coil overs installed but once they are, you just set them the same way you would on your bolt on coil overs. The springs set the initial height and you can add more pre-load as necessary or desired. :yup:
Moby's undercarriage looks good. Now take it out and mess it up again. [emoji1303]
Believe me, I'm dying to but I'm STILL waiting on parts from King :naw:
Looks like they're for Rubicat :)
Actually, they WERE from Rubicat :crazyeyes: :D
Those tires would look good on your guys' new truck.
:cheesy: That would be cool but it would also require a stupid amount of lift. :crazyeyes:
The track bar is backwards compared to stock. It's this way b/c of the Evo lever. I'm sure you adjust height based on much preload you put on the coilover.
The track bar is factory and it is installed backwards but I only did this because I thought it looked better. You can run it either way and initially, it was installed the other way. :yup:
sc_rhino
I just figured since the track bar is mounted on the front side of the axle instead of the rear (stock) side, that's why the bar was backwards.
Just when I thought they would never come!!
I can finally finish rebuilding Moby's EVO Lever and get him back on his feet again :wings:
Been a crazy busy week and weekend but I finally got Moby's EVO Lever back together again!! :wings:
In addition to servicing his front and rear differentials, I also got his rebuilt front drive shaft installed.
If that weren't enough, I also installed a new Odyssey battery as well.
benatc1
What's UP with WAYALIFE : Cindy & Eddie's Photos on the GO!!
Moby getting a lot of new life! That's exciting! Do you use a local driveline company for your driveshafts?
Productive week!
It really has been but it's also been a long time coming. Maybe way overdue :crazyeyes:
Yup, I use a shop here in Carson City called Jigsaw. Super fast turn around times and great pricing. I've used Bayshore in Sparks in the past but they took FOREVER and charged me a good chunk of change to do a whole lot of nothing. I mean, literally. I asked to have my shaft balanced, they said they turned it and it looked good so they did nothing other than paint it black and charged me for it. Of course, it took almost 2 weeks to get back and only because I kept calling. :rolleyes2:
benatc1
Good to know, I need to get some 1350 shafts soonish and was thinking of either buying some Adams or JE Reels but thought maybe getting them built would be good too. Don't mind driving to Carson for clearly better service so maybe I'll look into this option.
