If I get that 2.5 inch budget boost than I will want to get a xrc front stinger bumper because I saved so much money.
Will that weight drop my lift lower? And if it does how could I adjust to the drop?
Well it might. It might not drop it too much. You wont lose the whole lift if you do.
Baaically you have all the facts here in this thread - you need to weigh out your needs and figure out what the best value is for you. A quick recap:
A budget boost will give you the lift for less, allowing you the look you need. It is easy to install. You maintain ride quality and upgrade the ride height
A coil lift is more $$$ but has the option to add a puck if necessary after a weigjt change
Ride is 100% subjective, ride first and check it out.
