Without the app you have the choice of 4 default settings for RPM and impacts per minute.
Torque can only be adjusted through the app but will be saved. It’s a wide range of accuracy. Only meant to get you in the ball park.
After dicking with it for a bit. I also like that you can change the “ramp on” with the trigger pull length.
*copy/paste*
“Custom Drive Control
Adjust the RPMs to deliver more control for delicate fastening applications. Adjust the torque and RPMs to achieve repeatable torque results from repetitive fastening applications.
Lug Nut Mode
Eliminate the need for torque sticks by choosing between two settings that will deliver repeatable output on lug nut applications, and check final torque with a calibrated torque wrench.
Concrete Anchor Mode
Select this mode so the tool will automatically shut down once the anchor is seated to reduce broken anchors and stripped material.”
