Cleaned AC unit.
Cleaned AC unit.
Got the framework of the shed finished. Sanded with 60 grit palm sander and put a coat of POR Clear. Still need to decide on what skin to use and how I want to make the doors...
Starting to look that way.. lol
Just got a 50 year old home and found out that sprinkler systems weren't even attempted to be used for ten years. Surprisingly I only had one broken line I think. Just waiting for this to dry and recheck.
I know my buddy in Wrightwood has his burried pretty deep. He also used removable connectors for his valves and has a low point drain to drain and blow out his system in winter.Wow, sounds like you lucked out. Is it safe to assume you have to dig deep?
I'm curious about longevity with a connector like that. Roots and water hammer (too bad it's not water rubber mallet..haha) wreaks havoc on irrigation.Agh. Just fixed a bunch of sprinkler lines and sheared off T-fittings and heads last week.
If that patch doesn’t work. These make life easier. No waiting to cure and no leaks.
View attachment 307416 .
Only about 8 inches, not too bad.
