Close-up. Not pretty but it works. View attachment 110212
I can't believe that is all you had to trim. I pretty much had to cut a hole in mine. :yup:
Has to be installer error.. I didn't have to trim mine at all. Newer model thing?
Sorry here's the photo. Also the hole here (circled) had to be widened a bit to compensate for the raised bolt due to the a pillar mount.
Thanks for this Frank! This will help
Why not weld in cage?
I need to pull mine back out, they looked like crap after I was done trimming. You would have thought edward scissor hands worked on mine.
Put the door molding on the edges. It'll be cleaner.
:cheesy:
I actually took the door edge trim off my fenders for a cleaner look. I will take a buffing wheel to the plastic before I use the door edge trim inside my Jeep. :thumb:
