The building of Anvil II -- The Deuce
notnalc68
That dude from Mississippi
I replaced the standard fixed D-rings on this Rugged Ridge XHD bumper, with their D-ring brackets for shackles. No point to it, other than I think they look better. I used Rugged Ridge red powder coated shackles.
With all the D-ring talk going on, I'll say these are very well made, and only $58.99 at Quadratec.
From these...
To these...
From these...
To these...
Any particular reason you didn't go motobilt? :cheesy:
notnalc68
I'm making plans to re-gear. I won't go to 37" tires, on the current axles, so I plan to gear to 4.88. That should put me around 300 rpm above the stock ratio. Since it mostly pounds pavement, and is an automatic, I think that may be a good ratio. I miss the extra grunt it had with 4.10 and stock tires. It shifted a lot less in hills.
I checked with the only two shops I can find, near me. One said $1800-2000! The other said $1250-1300. The guy at the less expensive shop, had way more Jeep knowledge, than the expensive shop.
Napalm
That's not too terrible! Especially if he seems to be more knowledgeable.
GraniteCrystal
Seems as though prices are generally going up a bit for regear. Trail Jeeps used to do it for $1000 and its up to $1500 I think. ORE may be one of the last to still do for $1000 if they still do.
notnalc68
Yeah. He does a lot of Jeeps, so he won't have to order the parts. He asked what size tires I was running, and recommended 4.88 (which I had already decided on). He said he's never had anyone with auto trans & 4.88 say they wish they'd have run 4.56, but he said the opposite has happened. He told me to get a Procal, which I already have. All in all, it took about a minute of him talking, to tell he knew Jeeps.
