Nope, not all of them. Bummer
badass keychain. (I certainly hope it doesn't break and I need to call customer service)
Finally home for some much needed time off. First order of business was to dive into the mountain of parts and try to make some sense out of it. I have to toss a huge thanks out to Strizzy for the new King Airbumps and the badass keychain. (I certainly hope it doesn't break and I need to call customer service)View attachment 102351
After putting together a game plan,I started off with the rear EVO Fascia and D-Ring mounts. I had a bit of help for a limited time even. View attachment 102352
We picked up a plastic file folder from Walmart and used it as a backing for the EVO cutouts in the Fascia,rock skins and bumper end caps, we simply attached them with a bit of silicon. View attachment 102353View attachment 102354View attachment 102355..Doesn't look too bad once I installed itView attachment 102356 the trick to making the D-Ring mounts look good is to trim the ends of the frame rails as flush as possible. View attachment 102357.
Started the task of removing the ElCheapo skins I had added way before I knew something better was available. Tomorrow I'll lift the body a bit so I can get the Diamond Plate garbage removed completely and begin installing the new EVO ones. View attachment 102358
Lookin good lee! Trick is adjust the key chain correctly so it doesn't jiggle![]()
Lookin good Lee! Trick is adjust the key chain correctly so it doesn't jiggle![]()
Oh, and if it cracks or breaks, you didn't do it right...
In all fairness, this is an old model and the new version has more rubber webbing for strength. If there's any issues with it Lee, let me know and I'll arrange a replacement.
Wait a second... Why don't you just take off your bolt on sliders??? :idontknow: :cheesy:
You just had to ask, didn't you? So, I'm going to do like many before me have done..Pass the buck, lol.
In all seriousness I unfortunately cannot simply remove them anymore. There seems to be a set of control arm brackets welded over them, and no I didn't do the welding this time. Needless to say, it was quite interesting removing the body lift for sure.
:cheesy: come on that was too easy. I was hoping for some hmmmning and hawing for a while first!
You weren't expecting me to lie..Or were you?
No way. Just a little dance...
Really, the plan is to remove them in the not so distant future, which will render them undonatable, and install a set of EVO sliders once the Mrs and I agree on the configuration that will give her a flattish step similar to what is already there. But, hey, this is another one of those Pre- Wayalife mistakes that I'm slowly making right.
