So much for satisfyingI'm thinking my rush to winterize may not have been the best decision.
Since the coating remains fluid, this is what happens after a long trip of pretty much 80 mph the whole way.
I'm going to take some Degreaser and power wash it at the diy car wash, hopefully I can clean off a lot of the areas where I don't want it.
the wind blew it all overView attachment 436078
Jeep undercarriage winterized, ready for Utah winter.
It's Woolwax, gets sprayed on.What is that process/product?
Should have just went with used engine oil.It's Woolwax, gets sprayed on.
Had a distinct smell for about a week.
Welcome to Woolwaxusa - WoolWax Lanolin Auto Undercoating
www.woolwaxusa.com
www.woolwaxusa.com
Just got back from the car wash and the pressure wand was enough to remove the film from the areas the wind had blown it onto and areas that I didn't want it on.Thats the lanolin in it - looked it up - looks similar to fluid film. it's stinky
Not sure on the JL/JT tapping into the light harness may throw a code for light out the can network will see a voltage change.View attachment 436327
Found this hook holder on Amazon I think it looks better than having it hanging on the tow hook lol
Also auxbeam was having some holiday sales so I snagged some lights and a switch panel just waiting on the mounts for everything
View attachment 436329View attachment 436330
Has anyone wired aftermarket halos to the driving lights on non led JL/JT I tried tapping into the park/driving wires at the fender lights and no lights would work when they were plugged in. The auxbeam panel uses the same fuse for power as the halos so I need to figure something out lol
Man that’s just wild…how many miles?Got the Jeep back, so quiet and full rpm range ready
Cylinder 5 lobe was also worn and ready to make its debut of a misfire.
Some of these lobes are not like the others:
They look good. I did a similar install in the van. BD had a whole kit with replacement bucket that fit into the stock opening. They make a huge difference. Did you go with the SAE compliant ones or a different set?Wanted an upgrade from the factory fog lights but didn't want to bolt on a set. Bought a set of Baja Designs lights that mount inside the factory bumper. Simple install and uses the factory wiring. Super nice kit and got the set for $300 after I said I'll bolt a set on when they told me they were $450. Apparently the guy went to speak to his boss because they had another set on sale but not for a Jeep. 4wd Parts for the win again.
around 127000.Man that’s just wild…how many miles?
Damn seems low…? Poor casting?around 127000.
SAE and it was plug & play. Came with the replacement brackets and it was literally a 20 min install. This kit was well put together. I'm a fan of this product.They look good. I did a similar install in the van. BD had a whole kit with replacement bucket that fit into the stock opening. They make a huge difference. Did you go with the SAE compliant ones or a different set?
So was the sprinter kit I installed. I opted to save some money amd went with the squadron pros as they were cheaper than the SAE kit.SAE and it was plug & play. Came with the replacement brackets and it was literally a 20 min install. This kit was well put together. I'm a fan of this product.
imo, and I'm far from an expert but I think it's the cheap mass pressed rocker arms, I looked at a few and I bet if I were to take a micrometer to them, I wouldn't be able to create a full matching set out of a thousand of them.Damn seems low…? Poor casting?
I wonder if you scan that QR code if it links you to a heat number.
Stellantis castings sourceimo, and I'm far from an expert but I think it's the cheap mass pressed rocker arms, I looked at a few and I bet if I were to take a micrometer to them, I wouldn't be able to create a full matching set out of a thousand of them.
I don't know the manufacturing tolerances but if i were to guess, it's pretty broad.
