Flat Top
oh yeah, had to deal with this crap as well this week.
Sent from my SM-G955U using WAYALIFE mobile app
Catching up:
New 1350 rear (Adams)
Balance the front
Fix the EVO crossmember skid.
New exhaust.
Weekend work.
Intermittent P0394 + Traction control light = new Cam position sensor. For $50 I ordered 2 but the drivers side looks like a complete PITA (pulling intake). The passenger side was the source of the CEL so we will start with it. Fairly easy install although the old sensor needs a little coaxing to remove.
I could pretty much generate the CEL at will last summer. I needed 85+ degree day plus ~ 15 minutes at 80 mph. We will see pretty soon if this was a fix.
After replacing my unit bearings a couple of weeks ago with the short ABS wire unit I've been trying to figure out a solution for the shortness. Even after outing inside the frame the lines still looked short so I decide to try to make some plug in extensions. It might be overkill but for $14 in new parts I figured it was worth a try. I still had my old ABS cable from the original bearings so I had half the extensions, all I needed to do was figure out the female connector. Interwebs search lead me to a potential plug - Standard Motor Products S824 Pigtail. Amazon has them for $7 prime so it was worth a shot. Ordered a couple and sure enough they work perfect with the male end. The new plugs don't have the secondary red lock but the connection is still solid. Old male plus new female = new extension. Only odd thing was figuring out the color coding, 50% chance and I was initially wrong.
Original male black ---> new female red
Original male white ---> new female black
They ended up being ~13 inches long but only need to be about half that length. I wanted to err on the long side for now. Been running then for a few days w/out issue.
TLDNR
Standard Motor Products S824 Pigtail Female + Old ABS male end = ABS extension for front.
Nice job!
This reminds me I need to fix the rear locker plug before this weekend. Not sure when I broke or how but noticed when I was doing the rear coilovers.
Another fantastic trip to Wolf Caves (4-6 to 4-8) resulted in carnage and annoying / lingering issues.
A Rock and an Off Camber place =
Poser pic with no idea of the fun ahead.
Rock on the right, of camber to the left...
Actually less damage than I expected, the B-Pillar needs a little work before I cover with EVO skins but I'm not sure what to do yet with the rear panel. The EVO aluminum skids did their job mostly, except for the top tab being torn off. I guess that's expected since these were the aluminum skins.
Doing a check of the Jeep before leaving Wolf Caves I noticed my knuckle side drag link TRE was SHOT. The cotter pin was gone and the nut was half way backed off but seemed to be locked into place. I had quite a bit of play in the steering but was able to drive the 30 minutes to Llano to an auto parts that had a replacement. Swapped in a new one and safely on the way home.
During the check also noticed my stock evap skid had taken a pretty good hit and was bent out of shape (preview of coming fun).
Last week's commute to work resulted in lots of bump steer that started to lead to death wobble around 45-50. Determined the drag link flip insert was pretty worn so I've order a new one to be delivered this week. The pitman side TRE on the drag link also looks like it made contact with the trackbar (torn boot and grease on the trackbar) and not has slight pop/movement so I'll replace it as well.
Thursday I was greeted with a MIL light when I got to work. P1504, P0304, P0441, P0445 and P0456 all Pending Faults.
The P0304 - Cylinder 4 misfire will need to wait but all the others pointed to an EVAP canister leak.
Weekend work:
Inspected drag link, ordered new TRE for the pitman side. Rotated knuckle insert to try to get a better fit.
After getting the correct steering stabilizer bracket I remounted the SS. It helps with the bump steer/ DW and the over crappy Houston roads.
Rotate tires, they have gotten a off balance with the trips this year. Definitely help smooth things out and delay a trip to DT for balancing.
Pulled the evap canister to straighten the bracket (I hesitate to label it a "skid"). Found a crack in the canister around one of the hose connections. I tried to superglue / RTV the crack but not looking good. After re attaching and a couple ignition cycles I still have the code.
$120 for a new EVAP Canister?
Oh well, another $200+ bucks for a new EVAP canister and a new skid to protect it. I also broke the retention clips on the vent hoses. :crazyeyes: Just Empty Every Pocket... :gaah:
Once I get rid of the EVAP code I'll address the Cylinder 4 misfire.. New Head in my future?:naw:
Goddam Tom! We all need a break from Wolf Caves it seems lol
Last week's commute to work resulted in lots of bump steer that started to lead to death wobble around 45-50. Determined the drag link flip insert was pretty worn so I've order a new one to be delivered this week. The pitman side TRE on the drag link also looks like it made contact with the trackbar (torn boot and grease on the trackbar) and now has slight pop/movement so I'll replace it as well.
Weekend work:
After getting the correct steering stabilizer bracket I remounted the SS. It helps with the bump steer/ DW and the over crappy Houston roads but I still need to address the root cause.
Dang Tom! I actually came out pretty unscathed this time.
I agree.
That's quite the list! But nothing some beers and a few days in the garage cant fix up. :thumb:
The only clearance issue so far in my FANTASTIC MidArm RK rear lowers have the upper track bar bolt contacting the passenger rear bump stop. Looks like I can shave the bolt and possibly move the bump stop forward a bit.
Flip the bolt around. :thumb:
Welcome to the club!!100000 :crazyeyes:
