The purpose of the Rockstar skids is to get you better ground clearance. They aren't required if you don't have that concern.I just Took delivery of some fusion 4 x 4 axles which are Dana 60 and order new rockstar skids. It looks as though the bracket tree works without the skids, should I have any concerns not using the Evo brackets?
I may be wrong but I'm unaware of that requirement. I installed them on my JK with regular shocks and it just moves the mount 1.5" higher, no change in angle.I was thinking they had some sort of geometry correction for the coilovers as well? Not true?
The geometry of the bracket looks a little different but I think its because the mounting holes are more in the back instead of off to the side also by moving the bracket up puts the shock at a slightly different angle. But as far as I know its unrelated to the coil oversI was thinking they had some sort of geometry correction for the coilovers as well? Not true?
Sway bar link should be on the inside of the rockstar... :thumb:The geometry of the bracket looks a little different but I think its because the mounting holes are more in the back instead of off to the side also by moving the bracket up puts the shock at a slightly different angle. But as far as I know its unrelated to the coil overs
Thanks for the input guys appreciate the concern. I have since changed out to evo swaybar links and swapped that bolt after that picture was taken
