Ddays
I'm not putting on larger tires than I have now and the only steering components that end up in the frame are the flipped drag link (which is the big topic of discussion here).
Right now regardless if I do a 3" lift, 6" lift or 450" lift, if my upper bump stops stay in the same location, my tires and other components still STOP at the same location.
IF i go to larger tires I need to extend the upper bumpstop
If I flip the drag ling I need to extend the bumpstop
If I just lift it the bump stop does not need to extend. The problem I am trying to solve is why there is not a better engineered solution than flipping the drag link and subsequently having to add bumpstop? That's it. Not if I have bigger tires or I flip the drag link or if if if...
It's called innovation. Looking for a better answer and trying to understand if someone has already had the same thought process and ruled it out via sound logic and thought.
Oh boy, I don't even know where to start on answering this..
No one ever adds upper bumpstop - what in the hell is that? You always add bumpstop to the axle pad. As far as innovation, boy, you're right. None of us dummies ever looked for better answers or thought of that sound logic thingie :rolleyes2:
Carry on....
