Christarp
Ok, so let's get some information out of the way first. I've got a 3.5" RE superflex lift, and I love it! does everything I ask of it and more, no problems at all. Well, except one.
I ordered this kit sometime in january and installed it pretty soon after, and it all went together pretty flawlessly without too much rubber mallet coaxing. Anyway, I didn't really realize it at the time, but I have now and it worries me.
as you can see I've got about 6 and 1/4" of travel between the axle and a fully compressed bump stop: http://filesmelt.com/dl/P4230103.JPG
However, I've only got about 5 and 3/4" of travel between the top of the shock and the body of the shock: http://filesmelt.com/dl/P4230106.JPG
this means the shocks will bottom out before the bompstops.
Now, there are a few options I've been rattling around in my head, and I want the one that will benefit my style of off road most. I don't crawl too much, most of the time off road is spent going through muddy trails at relatively quick speeds, or going as fast as logic dictates on the sand, in both of those scenarios up-travel is a pretty big deal.
So, I could get bigger bumpstop blocks, this would be the easiest most likely. Or, I could replace the shocks with a smaller body shock which would allow for more up-travel, but less down-travel (correct?) I was leaning towards this option.
In the future I also want to add the kings air bumps (at least in the front), so I was also wondering how high relative to stock those mount when fully compressed.
The amount of travel I have between the tire and fender is 8" so I've got a good amount of room to play with: http://filesmelt.com/dl/P4230107.JPG
I've already gone through the sand bottoming out left and right with the current set up because well I wasn't going to delay a trip for 1/2" of bump stop, so I'm fairly certain the shocks have been used for the bumpstops already, but they still seem to be good, and not leaking or anything. I'm thinking the down-travel is limited already by my transmission crossover (which I was actually directed to remove in the instructions but nah even if it went down more the boot would just tear and it'll kill itself eventually anyway ) and driveshaft (my driveshaft has made a nice little curve in it already after one trip), so would getting slightly shorter shocks be THAT bad of an idea?
So, with all this information in mind, what would you all suggest is the best idea?
