jdofmemi
Thanks I'll be glad when it's done...now I sound like my wife. LOL
I know the feeling.
I haven't had a chance to do anything to my Jeep. Been working on hers all year.
Nice catch, eagle eye!Looks good. Did you remember to tighten the track bar jam nut?
The link comes with a open hole Heim joint instead of the stud heim like the other three link ends , so you can use the factory bolt and flag nut.
I purchased this from Accutune as part of their lift they sell , but It's Currie enterprise sway bar links.
Did the EVO tire carrier today , straight forward just as Eddie out lined in his video...which I used. :2thumbsup:
Used a 1.5" cheap spacer for the tire carrier...stock wheel....... factory tail gate bumper is to short to touch tire, need a longer one.
I used the small bracket EVO supplies for the third brake light...mounted it on top using the carrier bolt to hold it..... bent it backwards to point outward.
I cut the camera housing guard off the factory tire carrier and slid it over the camera and drilled a hole then screwed it in place.
Then added the locking cover too. just added protection, not sure if it will stay, I might take it off but just more protection for the camera.
The carrier should be adjusted to where the tire makes slight contact (with the carrier) before the lug nuts are tightened. That contact will isolate the tire from shaking or vibrating. No need for the rubber tailgate bumper any more...
