Andy5160
You can fix that
I am witnessing yours in person Jerry [emoji736]
You can fix that
Scanner worked. Had to re enter vin and it fired right up! Have 1 DTC for oil temperature sensor I need to get worked out but IT’S ALIVE!!!!
I have the same one after the swap. Still haven’t fixed it. 1,000 miles with no issues though.
I’m going to check the circuit with an ohm meter tomorrow and check connections etc. oil temp is one I had to add a pin for so hopefully it’s just a connection.
This is very anticlimactic
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Haven’t tried any burnouts yet. I did disrupt some gravel in the driveway “accidentally” testing throttle response.
