Build of my JKU
wjtstudios
I’m running the PR 60’s with the stock booster and M/C only running 37’s but the brakes work fine .
I swear DT said its not needed, but O well.
Sent from my SM-G781V using WAYALIFE mobile app
I’m not taking chances with 40s. I’ve been in a couple high angle drops that even with the bigger booster, it barely held the Jeep. Not a good feeling.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
MericaMade
I can get my hands on some KMCs for a decent discount and no tax and the ones I like are 4.75 backspacing. Is 4.75 gonna give me issues? I was under the impression that since the PR axles are wider I could run more backspacing?
Weebz
2015 JKUR AEV JK350
1985 CJ8 Scrambler
All the truth in that statement. Running the booster and all there are definitely times I absolutely want more stopping power.
Weebz
I don’t think so. Regardless you are going to need to clearance some fender lines. Adjust your steering stops and you should be fine.
MericaMade
Thanks its always the should be fine that worries me. Been searching my ass off trying to find and seems like I need to stick with 3.5.
And why the hell is KMC stamping for off-road use only on all there rings now?
fiend
What is the width of the Dynatrac axles you’re looking at?
I read somewhere you could get custom widths, but maybe that’s just the higher end XDs.
MericaMade
The standard PR60 package 68.5 I believe. I originally was just going to buy the same Method wheels I have just in 8 lug but they only come in 4.75 and the same for the KMC I like.
bhaner
I have the 68.5 wide axle and run a 3.5 backspace on a 17x10 wheel.
With 40x13.50R17's I just barely miss hitting the frame at full lock/twist.
My total width to outside of tire is about 88".
fiend
That should be fine for 37s but not fine for 40s. Unless you want to fiddle with your steering stops and have it steer like a battleship. Not sure which methods you’re looking at, but the MR105 comes in two models I believe, 4.75” BS or 3.5” BS. Plenty of people run 40s on the latter, but if you want the improved scrub radius you’ll want the additional backspacing and a wider axle. 72” for example.
MericaMade
Really, I'm at 79 and just barely fit through the trailer fenders on a 20 footer. I assume once you go 60 you need drive over fender or extra wide trailer?
Out of curiosity what wheels are you running? I really on see 17x8.5.
bhaner
On my 20' trailer I have drive over fenders. I also added two layers of 4x12's just to make it easier when the deck is slick. Totally doable with just the drive over fenders. You can also build wood ramps on the deck so you don't hit the fenders.
On my gooseneck it is a deck over so no issue there.
I have B.A.D. Wheels. They closed up shop right after I got them.
MericaMade
K, I'm just going to sick with 3.5 because once these 37s wear out I will step up to 40s. I don't want to do this again!
Ddays
Yup, 5:38's for the win. You'll be surprised how well it runs and accelerates. Until you get to the mountains. Woof. 🐶
