jeeeep
Front DS arrived today Coast 1310 - I've read through the install guide but also found an older thread that talks about dropping the shaft with each oil change to grease the center ball of the double cardan should I grease it before installing it?
There is a zerk fitting on the spline - what type grease should I use on this?
also saw where some are putting silicone on the yoke before it's installed - is this to control leaking?
Thanks for the input :beer:
