silverbackjk
I am having a issue with my coast 1310 drive shaft contacting my transmission oil pan. Is the cause of this is my axle needs tp be moved to the drivers side more or taller bump stops?
Have you checked to see if your axle is centered? If it is, you can purposefully set it off center so that you have more clearance or, do what you were suggesting with bump stops.
Is this the source of the vibration you have been trying to hunt down and have been discussing in another thread
That will work. I was also hitting the pan and skid plate. Did a little trimming but ultimately solved it with a long arm which controlled the axles much better.
I was not able to stop mine from hitting before the long arm, but I am running coilovers with huge flex. I think extending your bumps tops and cheating your axle over to the drivers side.
