adamjedgar
Hi guys,
Dealer put new engine in my Gladiator.
Dealer stated they had significant trouble bleeding air out of system immediately after the new long block engine install...so they then also replaced thermostat and water pump.
I drove car home however whenever I drive it, I can smell hot coolant...but have not found any leaks
Less than 1,000km...temp suddenly went through roof yesterday a few hundred meters from leaving my house.
Returned home, shut down, next day can't find any evidence of leaks anywhere underneath engine.
However,
Plastic overflow reservoir is empty.
I'm deeply suspicious as to where the water has gone.
First thought is, although I've done over 500km
Perhaps it had air in the system? Why it wouldn't overheat sooner if there isn't enough coolant in the system, or there's an airpocket, mystifies me?
My plan is to drain the existing MOPAR "yellow/orange" coolant (record volume of fluid drained) and then fully refill cooling system with Penrite OEM purple coolant (OAT)
Do JTs require any special method of purging air out of system? Can I "burp it" with funnel in overflow reservoir?
Does anyone have a video purging cooling system specifically on JTs given the filler cap is not mounted directly on radiator?
However,
