rinkishjk
the bearing/hub unit to the knuckle
A couple tool company's make a specific special tool for this, but u can do the same thing using a small extension on the three 13mm 12pt bolts that hold the unit bearing to the knuckle. U put the socket and extension on the bolt, and start the engine and turn the wheel to wedge the extension against the axle, and use the power steering force to push the hub out of the knuckle.
If u use a puller on the hub u will separate the unit bearing, and then u will need a new one.
