I have the 2.5" Terraflex spacer lift. I see several JK's in the area with 3" suspension lifts. My question is. Why do the suspension lifts look alot higher? More then the 1/2 inch.
Thanks Eddie. Wish I had known that earlier. So do I have to change driveshafts with a 3" suspension lift on my 2 door?Because a spacer kit will give you exactly as much lift as they are tall. MOST spring lifts will give you MORE lift than what is advertised.
