EVO Rear Bolt On
Rusty
Guys how far back does it move the swaybar? I think you guys just informed me that I can't install this on my jeep :crazy_eyes:
Unless I shim it down lower than my air system.. (pre lift new lift kit picture)
Rusty
Just an estimate, but I would say down 3/8" and back 1/2"
Thanks will look into this when I get home in 20 days. worst case scenario is.. modifying the sway bar a little lower..
Btw chris now that you have them installed are you enjoying them much?
pastorwug
Jesse - go to church this morning and you'll have a different perspective when you attack this again this afternoon. :yup:
JK's JK
Banned
I've got more questions.
The instructions say
32. Assemble upper shock bracket to coilover as shown. Add ½” washers to both sides of shock. This will help prevent shock rotation. Reservoir should be angled to middle of JK on both pass and driver sides.
Here is a picture that I have pre assembled. It says to add a 1/2 washer but the hole is way to big for the hex head and way to small to fit over the stud through the top of the CO. On the colored copy there are washers right next to the blue rubber........
Looking at the directions, there appears to be a total of 3 washers. One on the bolt first and one on each side of rubber INSIDE of bracket. Nut side does not show one.
JK's JK
Banned
That's what I'm talking about!!!! There are no washers!!!! or provided in the kit
JK's JK
Banned
So I'm now also looking at the mounting locations for the CO on the rockstar. Should it look like this? There was two small spacers zip tied to the bottom of the CO.
I'm still wondering about these 4 spacers that I have. Can anyone tell me what they are for?
JK's JK
Banned
The ones zip tied are from king, put those aside (don't use them ) use the ones included with the kit
Those in picture two? When I tried to fit them in at the rockstar they where super tight. Is that the way it should be?
The top. Per the instructions picture there are washers right next to the blue rubber. Is that the way is should be or a open gap with no washers?
