Ok here's an update...
Using the AEV procal today in the god forsaken heat here in Florida, I centered the steering wheel. It was off to the right by maybe 1/4 of a turn on the adjuster sleeve. Gonna see if it helps the bas/trac light problem.
oh good, hopefully that helps with the light. i once forgot to activate the turn signal before i unplugged the procal and my turn signals stayed on. :doh:
it usually takes a couple tries to get it exact. but it's a handy feature.
also , what kind of lift do you have? maybe you're tire wear can be figured out with some adjustments.
I'm running the AEV 3.5" lift. Never had a single problem until I got new tires put on. On the way home from discount tire the trac control fired off on a mid speed left curve. I knew then this was going to be an issue. I hope this takes care of the that issue. Now to figure out if I really need new tie rod ends. I don't have and play left to right or up and down. Just a lot of rotational slop which I have been told is normal. I still will most likely replace with a HD tie rod and drag link just because. It is a jeep after all that's what we do! This forum is a god send.
I figured I would post this since it might help you understand what a bad tie-rod and drag link look like. Both of mine are bad. I've been gathering all the parts to rebuild my suspension. The only thing that won't be new are the control arms, since for now they seem to be fine... plus I really don't want to drop another $600-1000 bucks on them right now.
Anyway, I made a short video showing what my bad tie-rods and drag link look and sound like. The are both very loose. Thankfully my jeep is not my daily driver.
https://www.youtube.com/watch?v=jntDXKuqstQ&feature=youtu.be
Also my front end is loose to the point that if I hit a bump the wrong way the front shakes some. I don't have the death wobble per say... maybe a little... but not to the point that I would trust my daughter to drive it.
Thankfully everything needed to fix the problem is in my basement
Yup same problem here. Jeep likes to drift to the left or right after hitting a bump. It like to dart left or right when coming to a stop on crowned or groved out roads. I replaced the ball joint just over a year ago and have only put maybe 15000 miles on them and they were easy miles at that. I had full on death wobble before the new ball joints. Never been so scared driving on the highway before. Took care of that right away. New ball joint and a new track bar and I was good to go.
