I am in the market for a new set of tires. For the guys running the Nitto Trail Grapplers 37s, whats the actual measured height of the tire installed?
Mine measured 36.85 inches at 32psi on a 17 inch atx slab wheel.
Air those bad boys down a little more makes a great ride at 28psi!
I realize we don't buy JKs for the fuel economy but those of you running low on tire pressure don't notice a difference ?
I have tried the 26 to 28 range and found the ride didn't change much from the 35 to 40 range but I can pick up 2 or 3 mpg's .
I am running 35 mud graplers on ATX rims .:thinking: View attachment 95996
i will have to try er out!!Air those bad boys down a little more makes a great ride at 28psi!
Measured from the ground to the edge of the shoulder, the point where the side wall turns 90° to become the tread, a 37" Trail Grappler will measure up to about 35.5"... maybe just a hair more. Of course, measuring from the center of the wheel to the ground and then multiplying that by 2 will give you the same results and really, these are the ONLY two ways you can an accurate measurement and is what you should use when calibrating your speedometer.
Having said that, you should ALWAYS refer to what is written on the sidewalls when talking about tire size and lift height. In other words, a 2.5" lift will clear an advertised 35" tire that will have an actual measurement of about 33".
