Aldonoward3
Has anyone lifted their jeep and then later on, added coil spacers along with the lift to achieve greater height and tire fitment?
I am running a Trailmaster 3.5 coil spring lift with front LCAs and I netted 5" front and 4" rear. My new winch bumper should lower the front about a half inch as it weighs only 61 pounds.
I want to add 2" coil spacers so that I can comfortably clear 37s and have that nice stance and clearance.
My gf is buying me all adjustable control arms for Christmas.
I may be wrong but I think the front drive shaft will be the iffy one to start but I'll be going tom woods soon.
I'm in the same situation, not sure what to look for in the way of correct bump stops?Assuming you're running 35s, I would trim the fenders and make sure you have the right bump stops before putting spacers on. It looks like that would let you clear 37s comfortably while keeping your center of gravity lower.
Lotsa choices. I was thinkin the same thing:banghead:
The rule of thumb for bump stops to to get them the same length as how much lift your running. So if you are running a 3" lift you want 2.5" or 3" bump stops to prevent the shocks from bottoming out and your coils from over compressing
Yup, what he said ^^^. Ideally, you want about the same amount of bump stop extension as you have lift as this will help to prevent your coils from over-compressing (squashing down to the point where they do not return to their original height).
Im running 2.5" coil lift, so im assuming some 2" evo bumps would be right? Also, is the a difference between "spacers" and "extensions"? Obviously i should have done it when i put the lift on as im now gonna have to pull thr springs again, but that wouldve made too much sense. :banghead:
So wuth a 2.5 inch lift, do i need new rear stops as well? And whats different between upper and lower?
yes you will. you should get axle side bump stops for the rear and for the front you can get axle side as well or get upper extensions. both will do the job.
