hbkid22
There's two "grounds" to consider:
The black wire that goes to the radio itself is a ground for the power supply. There are grounding studs in the cab (down past the door, below the dash).
The antenna also needs to be grounded, but the particular method you use to do that will depend on how and where you mount it.
'14 JKU, Billet.
Got it. That makes sense....I have to figure out where to mount it first. Want to mount on the rear but need to figure out a mount that will work with the setup I have....
Thanks.
