RKJK10
When you say fine are you referring to the fact that you re-torqued all front end bolts?
Yes every bolts are torqued to specs. every single joints on my suspension arms are worn out on the back end, I didn't take the front arms to inspect yet but I did retorque them all... unit bearings, rotors and pads are new lol, if the caster is set at 10* on the top of the balljoints and 90* on the large hole located on the front edge of the differential housing, good? or not good?
