You'll have to run trimmed or flat fenders up front to clear them and in the rear, you'll have to do some trimming of the pinch seam as well but, you might be able to pull it off. 3.5"-4" will do it for sure.
I wish I could do coil overs and I could set it up to a good low height but I just can't swing those. I'll have to measure but I'm pretty sure my garage sits at 6' 10" which will be a close one. Don't know why when it was built about 7 years ago they just didn't do a standard height.
I'll chime in for a second. Me and Eddie had a disagreement about lift and drive shafts. I will say that this past week while pulling my rear axle out I see where my stock shaft is starting to spite grease out. It lasted a few years but it's about done now. So make sure u keep that in mind.
I don't understand what your getting at. What does that have to do with a lift size and clearance so I don't rub?
With 3" up front, 2.5 in rear and cut fenders would 35's fit without wheel spacers or are they a must?
