Unless I am seeing this wrong, you gained over an 1" in the back? I thought this kit raised the back .75".
Did you install anything else? I have considered this kit as well. I was concerned .75" would not be enough. But yours looks great.
No this is just the kit parts which is two springs as well as two spacers. This kit offers more then just the 1.5 that it calls out for. I really like it and have no issues, did not need to do an alignment or have a hard ride. If you are considering this I would not hesitate one bit to get this and install.
I was really leaning toward the Teraflex kit, but now I may have to rethink this.
So when you install the rear spacer, did you leave the factory isolator in?
Thanks man.
Thanks man.
As USMC said you do leave factory isolate in and results will be different. I have a 2016 JKUR HR so I'm not sure what you are running. Once I put my winch and stinger on the front the jeep should sit perfect front to back.
I just can't wrap my head around how a .75" spacer gives more than an inch of lift. I guess I am overthinking it.
How do you figure?
The front of the EVO level kit is their 2 in springs, which may give you a little less or more depending on front bumper/winch combo. The rear is the coil spacer and should give you whatever the coil spacer is as long as nothing else is changed on the rear.
This is my point. Again, unless I am not seeing the photos correctly, the photo showing the space between the rear tire and the rear fender flare is showing over 1 inch increase. If a .75" spacer was added to the back, I would expect that dimension to be .75". I understand the front will be lifted 2+ inches.
How does the ride quality compare to stock with the "plush" springs now?
Ah ok, thats where you got it. Sorry, I really didn't look at those pics too closely. You don't want to really go by the fender flare to determine lift height really. Also if you look at the pics, the angle is slightly different in them. For the rear, you want to measure from the base of the bump stop to the plate that it hits on the axle. By base I mean the part of the frame where it attaches. You have to know the stock measurement of that also.
If Im wrong, somebody please correct me.
Either way, I like the look. I believe this has just gone back on my wish list haha.
