What shocks are you running?
I ran the nemesis ones on my old jeep. I had to drill a few holes but they went right on.
I had the bolt on one's on my Dana 30 and transfered them over.
So you had the bolt on Nemesis on a Dana 30 and you were able to transfer them over to a prorock?
I have metal cloak outboards on my Dana 30 but the MC guys said they don't work on a PR44. I need to take them off and see if I can get them to fit on the PR.
They should work just fine if you already have then
I'll see if I can get them on today. Not fun seeing your shock bend against the frame.
You didnt have to do anything for the coilovers on your pr44 right? I had to use the evo brackets on my stock 44 which moves the mounts out a little to clear the frame.
Personally I would call EVO or DYNATRAC to see what they would recommend.
Even less fun shelling out money to rebuild them...twice. Ask me how I know. :crazy eyes: :doh:
I'm not running coilovers. Just 2.5" shocks. They had enough clearance with the MC outboard mount on my Dana 30. I called dynatrac and they told me their mounts are moved outboard to help clear larger shocks but they didn't moved them out far enough. I talked with them a couple days ago in Moab and they didn't recommend any other mount. I'm hoping I can use my MC mounts. The Nemesis are pretty pricy.
I was able to bolt them on the PR 44 the same way as the 30. Had to drill the hole to mount just like on the 30.So you had the bolt on Nemesis on a Dana 30 and you were able to transfer them over to a prorock?
I have the MC brackets on my new jeep but I would think they could be made to work also.
I did the PR 44 like 3 years ago so I don't know if anything would have changed by now.
i thought the pr44 were already tabbed out but if not enough, that explains why the shafts did not move on the front shocks when I took them off. I guess I need to send them to the king to have them checked
The Kings are usually not pressurized high enough on the JKs to extend when removed. If you can't push or pull them you might have an issue but I would call king first.
