I'm not sure if you'll see that much difference height wise, but I can assure you, your ride will be superb.
I had the EVO 2 inch plush rides on my 2014 and used them for about a year and a half, and I can say that the ride is much better than any other suspension system i have ever used on any of my other Jeeps. I'd say go for it !
So, with the EVO leveling kit, would you say the ride is softer than stock?
It is leaps and bounds better than stock. It still keeps the stock feeling because it's a small lift, but definitely gives it the smooth ride of the plush rides. Definitely a great choice. I ran it then, and when the time comes I'll run it again on my Billet 2016.
Awesome. I was considering keeping the suspension bone stock with the 35s because I like the softer ride, but if the EVO leveling kit gives the same ride, I may go with that instead. The stock springs sagging is a concern of mine, even though the bumpers and winch will be pretty light. The leveling kit will help me compensate for that. I guess I'll have to see how much it sags, if any, after I get everything installed.
Now I have read about the plush springs sag a little is this true? What kinda lift can one expect from this leveling kit?
I never experienced any sag even after adding a bumper and a winch.
And the level advertises a "1.5inch" level. I got about 2 inches out of the front and about 3/4-1 inch in the rear.
Bringing this back . I'm looking at buying the 3" plush ride springs and needed a Lil more feedback as to what else I would need besides shocks and disconnects
Lower front arms, brake lines, bump stops.
It's better to buy the Enforcer IMO
Ok thanks I'll look into that. I was just looking at getting a quick budget boost to get myself off the ground. Then started reading about Evo plush coils. I plan on getting a full complete lift in a year or so.
Do what theyre all saying. Save a bit more and get the enforcer, and a front driveshaftOk thanks I'll look into that. I was just looking at getting a quick budget boost to get myself off the ground. Then started reading about Evo plush coils. I plan on getting a full complete lift in a year or so.
