JoeB-JKURX
Does anyone run the Staun (Coyote) inflatable internal beadlocks with regular wheels? I love my Level 8 Bully Pro wheels from Discount Tires (especially the fact that you can beat the crap out of the rock ring and just replace it when it is too trashed to use anymore - with zero damage to the actual wheel). On the other hand, I really like the idea of beadlocks to run at a low enough pressure to work in some extreme situations. It would seem that something like this internal beadlock would be an ideal solution to this situation. I know the DOT thing is confusing and that a lot of guys run beadlocks on the highway. That said, there is not even an issue with these internal beadlocks as they are really not much more than an inner tube (a very tough one though). The other thing that occurs to me is that outfits like Discount may mount and balance wheels with these installed (probably have to pay extra though). Not that Staun (Coyote) recommends it, but it would seem that you could even take the electronics for the TPMS and velcro (or otherwise attach) it inside the tire (it won't fit at the regular valve stem location but it would seem that you could remove the valve stem from the TPMS electronics and find a place - make a pocket, perhaps where it would fit). What do you think?
