highoctane
We are probably on the timeline of February or so.
If you don't want to wait that long, I'd honestly suggest to order through OTRATTW.
Ok. Thanks for the quick reply.
Well guys I wanted to give my review of the Trail Rocker.
So I have an 08 JK, so I purchased the 57002. When I recieved it in the mail I quickly opened it. The relay center is very well built, the wire are labeled for easy wiring, and they are plenty long enough to possible reach the rear bumper.
So upon install is where I ran into a problem. I could not get the relay center to line up on the battery mount bracket. Of course this was on Sat and Painless is closed. So I sent a message on Wayalife to Painless Performance about my issues and within minutes I had a response back. AWESOME! Andrew from Painless wanted me to snap a few pics of the bracket on the Trail Rocker and of my battery mount. So I did and sent them over. He was actually on the road traveling and would not be in the office till Tuesday. We sent a couple more email back and forth and by 10am Tuesday morning I had the trail rocker installed.
So the first issue was the bracket was missing a hole for mounting it to the battery tray. Andrew said they could send the correct bracket or I could just drill the hole. Easy fix by mocking it and drilling a hole in the proper place. Done.
Second issue is I have a Interstate battery that is taller than the stock. So the relay center actually hits the negative post on the battery. I was able to installed the negative terminal and the relay center and pull it down snug on top of the negative post. Andrew said as long as it did not come in contact with the positive that there should be no issue.
So after that the install went smooth and easy.
I now have my 20" light bar and 2 A pillars hooked up to one switch and it works flawless.
I do have to say that the Trail Rocker is a very solidly built product and would buy again. Now the customer service is above and beyond superior there at Painless.
Thanks again Andrew and Painless for your time and help. You guys are AWESOME!
I ordered the contura XIV for mine. They look just like the ones on the trail rocker so they should fit.... I'll let you know as soon as they show up
Figured I'd bump this thread. Any word on the custom switch covers availability? If I have to get them from OTRATTW what rocker do I need? They have a Contura II and III, Contura V, Contura XIV option.
Any word on the overhead switch panels?
We are still working towards the custom covers, but they are currently delayed. The Contura XIV from OTRATTW will definitely work for you.
The boxes are built and powder coated, we are just waiting for some tooling to properly crimp the connectors we went with. Since we made the box as compact as possible we had to use a different style insulated connector.
I have a question as well that maybe any of you that have one can answer. Is it possible to set up any of the switches ign. or batt. or is it one or the other?
