What size tire can I use without a lift kit? I was thinking about getting 33" tires with 17 inch wheels? Is that possible?
Welcome to WAYALIFE. To answer your question, without doing any modifications, you can run a 33 but you'll most likely see some rubbing at a full turn and when you're at a full flex. Nothing critical though. Ideally, you'd want to at least run a leveling kit to run 33's. If you're willing to do some trimming, as mentioned, you can get up on 35's but, I don't know if I'd recommend that without at least a 2.5" budget boost.
Front coil spacers/wheel spacers are ok? That's all I would need for a simple install with 32 and 33 it looks pretty good! No issues with normal driving?
It is not that much more compared to 2 spacers in the he front....Depending on brand you choose to get.[/URL]
I did not add new shocks and you really do not need with a leveling kit.The 1" front spacers are $18 each and you don't need shocks or sway bar links.
