WJCO
Meme King
Well decided to pull the trigger today and order a set of Cooper STT Pros, 37x13.50. Should be here this week and get them mounted up!
Nice. Congrats.
Nice. Congrats.
Awesome man! Cant wait to see it.
sent from my Illudium Q-36 Explosive Space Modulator
Congrats on tires! In terms of pinch seam, here is what I did. No rubbing. Same tires. 3.5" lift. Just did the JB Weld on it today. Picking up color match paint from dealer tomorrow. Also took half inch off the corner in the rear.Any one have pics of what they trimmed from the pinch seams to properly clear 37s, thinking about getting that done and painted before I even get the tires ordered (soon)
Congrats Ben. I went a bit more extreme with my cuts than GraniteCrystal [emoji15] I tend to over-do stuff. Got into the body filler/insulation and had to seal her up with a bit of RTV [emoji23]
Yeah, exactly. I cut into that insulation a bit as well. Here is another pic.Awesome, thanks for the pic, will give me a good idea where to start, I'm excited about the tires. Did you just use the JB weld to fill everything back in that you needed and smooth it all out?
I did mine with a dull hacksaw. Took like 45 min but you should see my triceps.I gotcha, thank you again- going to start hacking this week!
Seriously, use a sawzall or put a new blade on hacksaw. It was too tight to get my dremel in there.
I would see if you need to trim first. Welcome to the 37" crew!!! You won't be sorry
I didn't have to trim. But then I probably am running a bit higher( adjusted coilovers) in the rear.
I'd expect nothing less man! Looking forward to getting back out there with ya, your jeep getting close to being ready?
Getting there. Got the PR installed. The rear gear install kit was missing a carrier bearing so I have to get in touch with Dynatrac in the morning. Hopefully this week I can have her all buttoned up.
So where did toy scoop up those STT Pros in a 37x13.50 at? I'm in the market for some and I know that discount tire doesn't have any.Well decided to pull the trigger today and order a set of Cooper STT Pros, 37x13.50. Should be here this week and get them mounted up!
And if you don't mind me asking what did you pay for them?
Should be a pretty nice stance with the slabs, spacers, and the 13.50s. Looking forward to seeing it! [emoji109]
