H20JNKY
Bolt will snap from overtorque. Even if threads were damaged from overtorque, the chances of all 5 nuts backing off from that damaged location and then falling off would be near impossible. The ovaled hole indicates they were loose with studs rubbing into lug bores. I would replace the rim to be safe.
Makes sense. will replace the rim. Will be a good piece of mind.
