Sheaffadelic
I think he was saying he hasn't done that yet, lol.
i may or may not have missed that....... i should invest in glasses... :asshat:
Sweet build :thumb:
Great looking build so far :thumb:
 and here is a close up.
 and here is a close up. a couple of observations if you decide to put these on your Jeep. 1. The spring load will close the door for you so make sure you have your keys. 2. The curve of the passenger side mirror has a curve to it which distorts the view a bit.  Here is a picture that shows the gap between the mirror bracket and the guide plate when the door is closed.
 along with a matching rear diff cover
 I had the installer connect both a rear and front facing camera. The rear is installed on the factory tire carrier.
 I had the installer connect both a rear and front facing camera. The rear is installed on the factory tire carrier.  Here is the view on the display.
 Here is the view on the display.  The front camera is installed just under the winch plate.
 The front camera is installed just under the winch plate.  Here is the view from the display.
 Here is the view from the display. The last part was to install a USB port on the dash so I can connect my phone while it’s in its dock.
 The last part was to install a USB port on the dash so I can connect my phone while it’s in its dock. .
