A word of advice that can keep your hard earned money in your pocket.
Most of us will never run a JK hard enough to cause the performance characteristics of a high quality shock like a king 2.0 jk specific non reservoir shock to degrade.
I've run them in combination with sumo springs progressive bumps with awesome results.
The only reason i don't run the kings anymore is because i own a small 4x4 shop and i received a set of falcon non reservoirs for cost.][So far the falcons ride very similar to king 2.0's i actually like them a lot only time will tell whether they hold up as well as the kings.
now if your looking for adjustability that's a different story, personally i like to tweak things too much and if owned a set of adjustable's i would probably be constantly adjusting them to the point of frustration.
fyi air bumps can be a pia to get set up right
i've had good results with speed bumps and the sumo springs i'm running now.
So...the only reason you don't run Kings is because you're a reseller pitching Terraflex shocks you get for cost?
IMO you saying they ride very similar to is the same as saying eat snake, tastes like chicken.
your post sounds like you just became a TF vendor and trying to pitch your best profit margin product. Your OCD for adjusting has nothing to do well...with anything but maybe an infomercial
Sumo Springs, I've run them... they fell apart with all the bumps, crawling and overall a good year of trail use. I wouldn't recommend them to anyone who plans to hit the trails often.
I'd go with King or Fox speed bumps if you plan to be on the trails often. if mostly street, I'd stick with stock. Save your money, sumo springs not worth it IMO
