Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 174
Thread: Jeep JK Wrangler Unit Bearing Replacement Write-Up
  1. #161
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    6,299
    Quote Originally Posted by Clutch View Post
    I’m changing my passenger side tomorrow. Hope that makes the click click click go away!
    If you're clicking it could be a u-joint in the front axle shaft or your front drive shaft.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  2. #162
    Old Timer USMC Wrangler's Avatar
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    4,276
    Quote Originally Posted by BLReck View Post
    Excellent write-up and commentary. Thank you for that.
    I replaced both wheel bearings on my 12 JKUR and things went together without issue. I also had new u-joints pressed in both front axle shafts while it was apart, replaced brake pads and complete brake fluid flush/bleed.
    At start up, the ABS and TC light popped up and remained after d/c the battery briefly. Went for a short drive and all lights off so I'm feeling okay there.
    The problem I'm having is a pretty noticeable pull to the left after installing the wheel bearing, etc. I'm not entirely sure how this item would impact my steering. Any ideas or suggestions?
    Maybe your steering wheel was recentered when you bearings were bad and it needs adjusting again. Could also be that the new bearings are putting more pressure on worn ball joints, TRE’s, etc? Just a wild ass guess.
    Overall "build thread"
    http://wayalife.com/showthread.php?2...ker-quot-build
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    DIY trail/tube door build http://wayalife.com/showthread.php?24449-My-DIY-Doors
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  3. #163
    Old Timer Clutch's Avatar
    Join Date
    Dec 2015
    Location
    STL metro
    Posts
    3,151
    Quote Originally Posted by BaddestCross View Post
    Yea, if it’s still clicking I’ll have to dig in some more. We’ll see.
  4. #164
    Fresh Catch
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    20
    Are these the best wheel bearings to run bigger tires?
  5. #165
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    31,114
    Quote Originally Posted by TakHardRock View Post
    No wheel bearings are the 'best' for running larger tires, but Timken has a good solid reputation.
    "When the government fears the people, there is Liberty. When the people fear the government, there is tyranny."
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  6. #166
    Fresh Catch
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    20
    Quote Originally Posted by WJCO View Post
    Thanks.
  7. #167
    Fresh Catch
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    20
    Is 36mm socket correct size for axle nut? How come when I Google, some says 35mm, and some says 36mm? I have 2015 JKUHR.
  8. #168
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    4,276
    I bought and used the 36mm for my 2013.
  9. #169
    Fresh Catch
    Join Date
    Jun 2015
    Location
    Virginia
    Posts
    20
    Quote Originally Posted by USMC Wrangler View Post
    So you think same size on the 15? Just wanna make sure to buy the right size.
  10. #170
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    4,276
    I can’t say with 100% certainty. If I had to guess, I’d say yes. I followed this write up to do mine.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
