I'm fairly new to this stuff what all would I need in order to lift my jeep? I can't imagine it's easy as new shocks and coils would it be worth the money to buy a full kit then replace the coils? Or rather buy all the parts piece by piece until I have everything I need
Thanks
I can't imagine that there is a better lift out there that is also as simple as the EVO Enforcer.
Here's what you'll need.
1) Enforcer with 3" plush ride springs and shocks of your choice. 2.5" shocks will require EVO shock relocation mounts to avoid damaging the shocks.
2) EVO draglink flip kit.
3) New front drive shaft if you're lifting a 4-door. New rear as well if lifting a 2-door.
4) Some way to achieve adequate backspacing for your tires be that spacers or new wheels.
5) Trimming of the pinch seams/rock rails for tire clearance when stuffed.
6) Trimming of the plastic guard under the front bumper if you're going to keep the stock one. Otherwise your tires will rub when you are turning or stuffed.
It doesn't get much simpler than that. One thing that isn't needed but you should really consider is C-gussets as well with your larger tires.
eta: When I say that there aren't better lifts out there than the Enforcer, I mean at this level of simplicity.
