Page 17 of 27 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 267
Thread: Rock Hard 4x4 JK Sport Cage Installation Write-Up
  1. #161
    Nothing but a Thing M_Savage's Avatar
    Join Date
    Feb 2014
    Location
    So Cal
    Posts
    1,474
    [QUOTE=jnabird333;422368]Test fit done(ish)
    I need to pull the hardtop to finish the upper bars and rear, but it looks good enough for me to trust having it painted. I also need to drill the holes in the door frame, but that shouldn't take long.
    is it just me or is the upper crossbar suppose to go the other way; with the bends facing to the front of the jeep?
  2. #162
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,789
    Quote Originally Posted by M_Savage View Post
    Looks like it should but it doesn't.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  3. #163
    Web Wheeler 10frank9's Avatar
    Join Date
    Mar 2012
    Location
    So Cal
    Posts
    13,230
    Quote Originally Posted by OverlanderJK View Post
    ^^^this^^^
  4. #164
    Been Around the Block jman_12's Avatar
    Join Date
    Oct 2014
    Location
    Birmingham, AL
    Posts
    385
    Can this be installed on a 2 door fairly easy? I just wondered if the rear sections would work also lol
  5. #165
    Nothing but a Thing pastorwug's Avatar
    Join Date
    Oct 2011
    Location
    California
    Posts
    1,691
    Quote Originally Posted by jman_12 View Post
    Easy is a relative term, but yes, I've seen it in many 2 drs.
    Pre-fitting before powder coating is the way to go!
    2011 JKU Stone White Rubicon
    Chazak ve Amatz! חֲזַ֖ק וֶאֱמָ֑ץ Be Strong & Courageous! Joshua 1:6
    "praesis ut prosis ne ut imperes"
  6. #166
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,789
    You don't use the rear section with a two door.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  7. #167
    Knows a Thing or Two BadApple's Avatar
    Join Date
    Apr 2013
    Location
    Surprise, Az (Kunsan AB South Korea)
    Posts
    908
    They do make a rear section for a 2dr
    BADAPPLE
    2011 Wrangler 2dr with some stuff added!!
  8. #168
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,789
    Quote Originally Posted by BadApple View Post
    Yes I know but it's not the same and is additional and only works with the factory top.
    2012 Dozer JK
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    -Dynatrac PR60/PR80
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  9. #169
    Join Date
    Apr 2013
    Location
    Posts
    908
    Oh gotchya
    BADAPPLE
  10. #170
    Join Date
    May 2013
    Location
    Sabina, OH
    Posts
    2,633
    I've been meaning to add these... I wasn't able to find anything to give me a warm fuzzy on the cut that is needed on the dash so I thought I would add these to help others.
    I will add that when researching the install, it seems some have been able to install this cage without cutting the dash. In my case, the dash puckered up and new A-pillars didn't fit right without it. I called Rockhard to confirm the cut and they said it was in fact needed yet only offered a verbal description of the needed cut. This really isn't that hard to figure out, but I would've liked this picture when I was test fitting to verify what I thought was needed.
    In this picture you might be able to see the pencl mark (green circle) where I needed to start the cut/notch. Note: I later also ground down the dash support a bit (circled in red) to allow the side to fit more inside the dash.
    Here is the cut from the side, before I cleaned it up with a file.
    Same cut and after a little filing.
    I used a good (new) razor knife. (the kind that has the notches to break off for a sharp tip) I took my time and it worked very well... Anyway I hope this helps someone.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
