Page 50 of 64 FirstFirst ... 40484950515260 ... LastLast
Results 491 to 500 of 639
Thread: CJ buggy build
  1. #491
    Knows a Thing or Two klungly's Avatar
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Still waiting in some tubing to come in, so I've been going through all my short cuts and adding supports. Stiffened up the rear with a few. And final welded some that had already been cut and notched.
    Attached Images Attached Images
  2. #492
    Nothing but a Thing BABOOZLE's Avatar
    Join Date
    Apr 2015
    Location
    Washington
    Posts
    1,063
    Looks stout.
  3. #493
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Fuel cell supports are in. I'm really happy with how the fuel cell fits in the cage. Put the seats in to start working on the steering done.
  4. #494
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Made a mounting plate for my power steering reservoir and mounted it.
  5. #495
    Fresh Catch weck's Avatar
    Join Date
    Apr 2018
    Location
    Minnesota
    Posts
    12
    real nice build. looks great and close to being able to wheel it.
  6. #496
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Quote Originally Posted by weck View Post
    Thank you, now the hard part begins.
  7. #497
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Took out all the old wiring and fuse box. Going to make a very simple harness with relays and circuit breakers instead of fuses. Took out the old dash to make a new one. Made a mounting bracket for the u joint that holds the steering column.
  8. #498
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Closed up a few holes in the fire wall, still need to clean the patches up. Remebered how much I don't like welding sheet metal.
    Started working on a plate to mount the steering column and orbital valve on.
  9. #499
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    29,529
    Quote Originally Posted by klungly View Post
    Remembered how much I don't like welding sheet metal.
    Agreed. So tedious and defeating.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  10. #500
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    557
    Added some supports going from the shock hoops to the section of frame with the engine mounts. Should help stiffen everything up front when I cut out the unneeded part of the old frame. Started plumbing the transmission cooler lines. I wanted to make each line out of a single piece of tubing. Got a little too short on this line. Hopefully the next on I can make the way I want it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
