Page 58 of 65 FirstFirst ... 8485657585960 ... LastLast
Results 571 to 580 of 643
Thread: CJ buggy build
  1. #571
    Addict JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    9,838
    Quote Originally Posted by klungly View Post
    Made progress on the new yoke
    Does making the yoke shorter make the shaft stick further in to where the u joint will be?
  2. #572
    Knows a Thing or Two klungly's Avatar
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by sipafz View Post
    That really turned out nice!
    Thank you!
  3. #573
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by JKbrick View Post
    Yes, but the super short sye from jb conversions uses a really short yoke. I have to shorten it to be able to get thread engagement for the yoke nut. The new yoke is about 1/2" longer from the start of the splines than the old yoke. I'll still need to take it to work and turn it on the lathe. The sealing portion diameter is about .070" wider and will have to lengthen the sealing portion to .750".
    Attached Images Attached Images
  4. #574
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    All the machining is done on the transfer case rear output yoke. Everything fits nice and tight. New drive shaft is in. The next nice day I'll take it outside and make sure the transmission works after it was rebuilt at home.
  5. #575
    Nothing but a Thing 13_gecko_rubi's Avatar
    Join Date
    Jan 2014
    Location
    Commerce, MI
    Posts
    1,144
    Nice work!
    Sent from my SM-G960U using WAYALIFE mobile app
  6. #576
    Old Timer jdofmemi's Avatar
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    3,736
    Great work. I've been following your build, and you have a good one in the works. It's great you have the skills and tools to do all the things you show.
    Looking at the driveshaft pic, have you checked how much spline engagement you will have left at full droop?
    It could be the angle of the picture, but it looks like the control arms are longer than the driveshaft, so it will stretch as it drops.
  7. #577
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by 13_gecko_rubi View Post
    Nice work!
    Thank you!
  8. #578
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by jdofmemi View Post
    Thank you. I had the same concern. I lifted the rear end until I was at full droop and still had spline engagement. There is 8" of splines there. If there turns out to be not enough, I'll shorten my control arms an inch or two.
  9. #579
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    6,350
    Typically doesn't the DS shorten when the axle droops?
  10. #580
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    6,456
    Quote Originally Posted by jesse3638 View Post
    Thinking the same... Need to test at full compression.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
