Page 61 of 65 FirstFirst ... 11515960616263 ... LastLast
Results 601 to 610 of 643
Thread: CJ buggy build
  1. #601
    Knows a Thing or Two klungly's Avatar
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by WJCO View Post
    Looks great. Nice to see some paint on there.
    I have that same circuit breaker. Had it for about 2 years or more, no issues, works great.
    Thank you. Definitely like seeing paint over than the rust🤣
  2. #602
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Quote Originally Posted by sipafz View Post
    What a great hobby! I wish I had the space and time for such a project. Love seeing your progress!
    Thank you, there never seems to be enough space
  3. #603
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    I finally remembered to make some reservoir spacers for my coilovers. I uses some scrap plastic we had laying around at work.
    Attached Images Attached Images
  4. #604
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Started welding in the floor pans
  5. #605
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Making progress on the floor pans, learning how to shrink steel. Definitely a steap learning curve
  6. #606
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Getting closer to hitting the trails. Got a new front drive shaft from Adam's
  7. #607
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    I knew the new yoke for the front drive shaft wasn't going to fit as is but I knew I could make it work with the stock flange and a half round yoke. I took the flange to work and cut it to size, turned the outer diameter concentric with the spline diameter and bored the inner diameter .002" under size for a press fit. I'll press the new yoke into the flange and weld them together. I'll have to make a mandrel to use while pressing them together to get the splines to line up. That tooling should be here in about a week.
  8. #608
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Got the yoke figured out. I made a nut to help press the new yoke inside the old machined yoke flange.
  9. #609
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    558
    Welded the yoke together. Installed it on to my transfer case and put my transfer case back in after remembering I forgot a gasket. Installed the front drive shaft. Did an full extension test, the splines didn't move.
  10. #610
    Addict wjtstudios's Avatar
    Join Date
    Nov 2016
    Location
    Rochester, MI.
    Posts
    7,806
    Watch you build rigs like this is just amazing! Unbelievable skills
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
