Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
Thread: I NEED HELP (jku) I messed up off roading
  1. #1
    Fresh Catch
    Join Date
    Apr 2017
    Location
    Atlanta
    Posts
    2
    I let a buddy drive while I recorded while we were on a trail. Kind you my jku was completely stock suspension. So he tries to go over something we didn't have the clearance for and he busted my whole drivers side suspension.
    My first question is..... is it really bad ??
    Second: is what is now currently damaged or broken replaceable through a spring and shock lift kit. The whole kit and kaboodle? And if you know of a lift around the $600-$800 range that can either get everything going againIMG_6552.jpgIMG_6553.jpgIMG_6555.jpgIMG_6554.jpg or just about can you share the link with me ??
  2. #2
    Fresh Catch
    Join Date
    Apr 2017
    Location
    Atlanta
    Posts
    2
    My jk drivers side suspension is busted
    I let a buddy drive while I recorded while we were on a trail. Mind IMG_6552.jpgIMG_6553.jpgIMG_6554.jpgIMG_6555.jpgyou my jku was completely stock suspension. So he tries to go over something we didn't have the clearance for and he busted my whole drivers side suspension.
    Second: is what is now currently damaged or broken replaceable through a spring and shock lift kit. And if you know of a lift around the $600-$800 range that can either get everything going again or just about can you share the link with me ??
  3. #3
    Knows a Thing or Two Tylersilverjku's Avatar
    Join Date
    Oct 2015
    Location
    Phoenix AZ
    Posts
    607
    Well I'm no expert but I'd have to say your tie rod is bent but could be bent back, the drag link looks unfixable, the coil purches look bent and also the shock mounts seem are broke off too... also if your axle is bent you need a new one... there's probably more we can't see it looks pretty bad...
  4. #4
    Addict GraniteCrystal's Avatar
    Join Date
    Aug 2015
    Location
    Denver, CO
    Posts
    6,065
    Dang. Need drag link, tie rod, shocks...I don't even see your springs.
    I'd start by not letting him drive again.
    A standard lift kit with drag link flip will have all that. It won't be $600. If you want to get up and going cheap, jump on Craigslist and FB right now and find someone that has a Rubicon and just put a lift on. You'll need all 4 springs (unless yours is a Rubi, in which case you can just replace the broken ones), shocks (they should be red), drag link, and track bar too if they have it (can't tell if yours is damaged or not).
    This is to day nothing of ball joints. When you jack up a wheel, is there play in it when you push on it?
  5. #5
    Join Date
    Aug 2015
    Location
    Denver, CO
    Posts
    6,065
    Looks like your wheel is jacked up too. Again, Craigslist and FB are your friends. If those aren't anything special, you can usually find a set of 5 takeoffs from a Sport for around $200
  6. #6
    Join Date
    Aug 2015
    Location
    Denver, CO
    Posts
    6,065
    And what's hanging down to the ground in the 3rd pic?
    Your bill is getting pretty large at this point.
    May also want to take some measurements of the frame and see if that got twisted at all.
  7. #7
    Nothing but a Thing Speedy_RCW's Avatar
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    1,213
    Quote Originally Posted by New_Jeeper View Post
    Welcome to WAL. Stop by and give us a wave. As for your...umm....predicament....it's hard to tell what all is broken. Tie rod and drag link for sure need replaced. Looks like your mounts are jacked on the axle and it's very possible the axle could be bent. It also looks like your axle is heavily rotated forward so I'm assuming either your control arms and/or mounts are broke. Your springs are probably okay but I can't see them, do you even still have them? The only way you're getting that thing back together for 800 is getting all take off parts and that's only if you can pick up another 30 for super cheap. Post some pictures of the axle from the pinion side so we can see the control arm mounts and driveshaft.
  8. #8
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    25,011
    Before anyone gives any advice you need to post this video. This has to be epic for someone to fuck shit up that back.
    2012 Jeep Wrangler
  9. #9
    Hooked jkrichard's Avatar
    Join Date
    Jan 2016
    Location
    Canada
    Posts
    109
    Holy shit.... not enough clearance and doing highway speed? That's going to need some serious help.
    I hope you took your friend's shoes away before you tied him to the bumper to pull you home.
  10. #10
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    1,213
    Quote Originally Posted by OverlanderJK View Post
    ^^^^^ agreed
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
