Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Installing Evo Long Arm on half at a Time
  1. #1
    Been Around the Block phillypete's Avatar
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    319
    I just recieved my evo Long Arm kit and Iím an excited to get cutting. Being that my JK is also my daily driver, Iíd like to minimize downtime.
    From what iíve heard the long arm install is an arduous journey of self doubt, remorse and finally overwhelming joy.
    Would it be safe and/or feasible to install one half (letís say the rear end) of the kit and drive it that way for a week before finishing the second on the following weekend?
    Attached Images Attached Images
  2. #2
    Nothing but a Thing Benito's Avatar
    Join Date
    May 2013
    Location
    New Mexico/Texas
    Posts
    1,293
    Yes, that is perfectly fine, just be sure you have completely completed the rear end before you try to drive it... and continue to the front
  3. #3
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    319
    Quote Originally Posted by Benito View Post
    What if I do just the right side... jk... lol
    Thanks for the reply! This takes some anxiety out of this install.
  4. #4
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,710
    Having installed a long arm lift (Full Traction 3") in my garage on Jack stands I'd say it's going to be a lot of work to get half done in 2 days. You have to take into consideration you'll probably have to drop the gas tank for the rear and pull the exhaust off for the front. I'm not sure if EVO's kit still requires cutting and rotating the exhaust loop or not. If you have access to a plasma cutter it'll make it go much quicker. I could have used one but having never used one I didn't trust myself not to cut through something I didn't want to. 2 angle grinders, 1 withcutting wheel and one with 30 grit flap wheel will save having to switch wheels. Buy several 1/2" drill bits, DeWalt pilot point bits I found worked well. They didn't walk and they cut fast. They will dull and I think I went through 3 or 4 of them. All said and done it took me 3 and a half week's working on it 5+ days a week, 6-8 hours on my days off mostly by myself. I also installed a EVO draglink flip kit and front and rear drive shafts. I did have to wait for replacement parts because I received some incorrect ones so that set me back a bit too. It's very ambitious and not worth rushing. Maybe plan on a rental car as a back up plan.
  5. #5
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    319
    Quote Originally Posted by jesse3638 View Post
    Jesse, thanks for the heads up!
    For me part of the fun is trying to plan out these projects with limited downtime. So any further advice would be greatly appreaciated.
    I have access to a plasma and know how to use it. My plan for when we take the Jeep out of service is to have me on the plasma and my oldest son on the angle grinder following behind me.
    I am getting a flex exhaust kit to get back on the road ASAP.
    Is there any work that can be done prior to cutting? Can any of the brackets be located and drilled before cutting away the old stuff?
    Thanks for your help.
  6. #6
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,710
    Quote Originally Posted by phillypete View Post
    Unfortunately there isn't much that can be drilled with out cutting and smoothing first. Also don't be like me and try to work around the axles and drive shaft. Take them out so you can have more room. Also if you're working of of Jack stands sliding a tire under there with a moving blanket can give you more leverage to lean up against. You can install the bump stops on the axles with out cutting.
  7. #7
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    319
    Step one: inventory!
  8. #8
    Caught the Bug BPA's Avatar
    Join Date
    Jun 2015
    Location
    Santa Clarita
    Posts
    91
    subscribed! l too am looking to get evo long arms installed in my jeep in the future.
  9. #9
    Join Date
    Apr 2013
    Location
    Kansas City, MO
    Posts
    319
    I was under the Jeep plotting out the install last night. To me the front end seems much more straight forward.
    Since Iím doing half at a time is it better to start on the front or rear?
  10. #10
    Nothing but a Thing Speedy_RCW's Avatar
    Join Date
    Jul 2015
    Location
    Northern California
    Posts
    1,990
    I did the math and think itís exactly 50/50.
Similar Threads
  1. HALF TIME - Rugged Ridge JK Half Doors for MOBY
    By wayoflife in forum Jeep Show & Tell
    Last Post: 03-31-2018, 06:13 PM
  2. Long time listener first time caller
    By RobJKR JKUS in forum Give us a Wave
    Last Post: 01-25-2017, 01:14 AM
  3. Installing Evo Long Arm Upgrade
    By DWiggles in forum Jeep JK Wrangler
    Last Post: 01-14-2016, 01:49 AM
  4. First Time Jeeper, Long Time Creeper
    By ali@home in forum Give us a Wave
    Last Post: 08-15-2015, 07:55 AM
  5. Long Time Lurker, First Time Poster
    By aswoboda in forum Give us a Wave
    Last Post: 01-23-2015, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
