dchew
Took Oso on his maiden voyage yesterday and it wasn't good. When in an extended tight turn for maybe 10 feet or so (like pulling out of a driveway) there is a loud clank from the front end then the Jeep wants to pull to one side. It feels almost like it is in 4wd on pavement. Then it works itself out and drives fine until the next extended tight turn. This all happens while in 2wd. Jeep is a 2013 JKUR manual trans.
Changing the gears was the one thing we didn't do ourselves in this build. We sent the housings off to have that done (4.88's installed).
Here are all the possibilities I think:
1. Steering: Installed a PSC ram, new gearbox and pump. I really don't think this is the problem because if you steer lock to lock without moving the Jeep there are no problems. I can turn the 37's in place with my pinky.
2. Axle shafts: Installed RCV shafts in the front. That install was pretty straight forward, but perhaps something is binding?
3. Gears and or rubi locker: This is what I think is at the top of the list. I've never driven on pavement with the locker engaged. What would happen if that was done in a turn? Would the tires just howl and slip or would the differential give?
Another big clue that I should have noticed: When torquing the wheel spacers with the jeep on a lift, I did not need someone to hold the other axle to keep it from spinning, but I did on the rear.
So here are some things I'm thinking of doing:
Any other suggestions?
Dave
- Lift up the jeep and run it while on the lift. Put it in gear, turn the wheels and see what happens
- Try locking and unlocking the differential. I have not tried that yet for fear of implosion…?
- Go in the corner crying and sucking my thumb
Dave
